Setting up sale prices for individual products
You can set sale prices for individual products and product variations in your store. When you put an item on sale for a lower price, that value overrides the default price. So the original price is shown struck out, and the product gets the "ON SALE" label.
On the storefront and on the product page, sale prices can be displayed as a percentage or as an absolute value.
Setting ”Compare to” prices for products
An item that is on sale needs to have the actual price it’s sold for and the original price, also called the "Compare to" price.
If your product does not have variations, or you want to keep all your product variation prices identical, you only need to add the ”Compare to” price to the product itself.
To set “Compare to price” for a product:
  2. Open the product you want to put on sale.
  3. Set a new actual price in the Pricing field (if needed).
  4. Click Manage pricing options next to the price.
  5. Set the price in the "Compare to" price field. This value must be higher than the value in the Pricing field to show a sale price:
  6. Save the changes.
That’s it! Your item that is on sale will now have the "ON SALE" label and the savings info both on the storefront and on the product page.
By default, product variation sale price mirrors the base product sale price. So if you set the “Compare to” price for your product, the same “Compare to” price is applied to all its variations. You can set individual sale prices for your variations if you need.
Here is how a product with a sale price will look in your store:
Setting ”Compare to” prices for product variations
You can set a separate sale price for each of the variations your product has.
After you add sale prices for individual product variations, customers will see the price of the default product variation when viewing your storefront. When they select a specific variation on the product details page, the sale price will be adjusted. If your product does not have a default product variation, the base product price is displayed at first.
To set “Compare to” price for a product variation:
  2. Choose the product.
  3. Go to the Options → Variations tab.
  4. Find a variation you want to put on sale, then click Manage:
  5. Set a new actual price in the Price field (if needed).
  6. Click on the arrow icon next to the Price field.
  7. Set the price in the "Compare to" price field. This value must be higher than the value in the Price field to show a sale price:
  8. Click OK, then Save.
That’s it! You’ve added a “Compare to” price for an individual product variation. Now when a customer selects this variation on the product page, they will see the savings info for it along with the "ON SALE" label.
Choosing the “Compare to” price layout
You can choose how the sale prices look in your store: specify if savings are a percentage or an absolute value and where the price is displayed.
To set the sale price layout:
  2. Scroll down to the "Compare to" price section.
  3. Make the necessary changes:
  4. Click Save.
You can additionally change the default text on the "ON SALE" label (e.g., into “Lower price!”).
Setting “Compare to” prices in bulk
You can set sale prices in your store in bulk. For example, when you run a Holiday sale or want to clear out stock. There are several ways for you to create sale prices for products in bulk:
  • Promotions. Allows you to create sale prices in bulk for both products and categories in percentage or in absolute values. You can schedule when to run a sale by choosing the beginning and ending dates for the sale prices to take effect. All discounts you create are saved in your store admin, so you can reuse them in the future sales.
  • Bulk Product Editor. Allows you to change products prices in bulk. You can change product prices in absolute values only.
  • Mass update. Allows you to quickly change the price for products based on your current product prices either as a percentage or in absolute values.
  • Catalog import (with CSV file). If you're used to working with spreadsheets, you can add sale prices in bulk through a CSV file.
When the sale is over, you can similarly use any of the tools above to remove the "Compare to" prices and set new actual prices. With the advanced discount setting, prices automatically return to their original values once the sale is over.
Related articles
Product ribbons
Bulk Product Editor
