Buying shipping labels for the UK (Click & Drop)
Royal Mail Click & Drop is an online service for parcel shipping management. If you’re an ecommerce seller based in the UK, you can use Click & Drop to create and print shipping labels, book collection or drop-off services, track parcels all in one place, and more.
You can connect your online store to Royal Mail Click & Drop to sync your order info to this platform and manage shipping from your Click & Drop account.
Connecting your store to Click & Drop
You can connect your online store to your Click & Drop account to automatically export order data to Click & Drop. Connecting your store is possible only if you have one of the following shipping methods set up and enabled in your store admin:
Automatically calculated rates from carriers except for Royal Mail, order pickup, local delivery, and shipping methods set up via apps from the App Market are not supported.
To connect your store to Click & Drop:
  1. Sign in to your Royal Mail Click & Drop account.
  2. Go to Settings → Integrations → Add a new integration and choose Click & Drop API.
  3. On the integration setup screen:
    • Select your default trading name.
    • (optional) Tick the “Create batches for the imported orders” checkbox.
    • (optional) Tick the “Use shipping address for billing address” checkbox.
    • (optional) Rename the integration, for example, to “Store”.
  4. Click Save to apply the changes and close the setup screen.
  5. In the Integrations list, click the name of the integration that you’ve just added.
  6. Copy the API key:
  7. Click Update and Connect and check that the status of the integration in the list is now indicated in green:
  8. From your store admin, go to Shipping & Pickup, scroll down to the Integrations block, and click Set Up Integration next to Royal Mail Click & Drop:
  9. Paste the API key you’ve copied in the field:
  10. Click Activate Integration to make the sync active.
  11. (optional) On the opened page, update the default integration settings if you wish:
    • Under Orders to export, choose which orders you want to sync to Click & Drop. By default, “Paid orders only” is selected to ensure every order in Click & Drop is paid for. If you choose “All orders” instead, all placed orders will be sent to Click & Drop immediately, regardless of whether they are paid.
    • Under Shipping methods to integrate, choose shipping methods you want to use with Click & Drop. Only orders that were placed with these shipping methods will be synced to Click & Drop. By default, all your enabled Royal Mail shipping methods (if any) are selected.
  12. Click Save.
That’s it! You’ve connected your store to Royal Mail Click & Drop.
Now all the new orders with payment statuses and shipping methods that fit your settings will be automatically synced to your Click & Drop dashboard. Orders you got before connecting to Click & Drop will not be synced.
If an order didn’t sync for some reason, you will see a notification in My Sales → Orders. You can sync the order manually by opening it and clicking the Export again button on the page of the order.
The following order data will be exported to Click & Drop:
  • Customer details: full name, shipping and billing address, email, and phone number (if available).
  • Package contents: product names, quantities, prices (without taxes), and weights.
  • Order value and subtotal, tax value, total weight, shipping method chosen and its cost, customer order comments.
After an order is synced, you can generate shipping labels, book collection or drop-off services, and more from your Click & Drop dashboard.
As soon as Royal Mail marks a successfully exported order as shipped, then, within 4 hours, the fulfillment status for this order will automatically be changed to Shipped in your store admin, and the corresponding “Order shipped” notification will be sent to the customer. If the order also has a tracking number, it will be synced to your store, where you can find it on the Orders page, and the notification will also contain the number.
Tracking number/fulfillment status data will not be synced to your store if the order is shipped by Royal Mail later than 14 days after it was placed in your store.
Editing Click & Drop integration settings
After you connect your store to Click & Drop, you can edit the integration settings at any time. For example, if you want to change the list of shipping methods used with the integration, decide to sync all the orders (and not only the paid ones), or want to temporarily stop orders from syncing.
To edit Click & Drop integration settings:
  1. From your store admin, go to Shipping & Pickup, scroll down to the Integrations block, and click Manage Integration Settings next to Royal Mail Click & Drop:
  2. Make your edits. Change which orders you want to sync (all or paid only), choose your shipping methods, or set the automatic order export status to Stopped.
  3. Click Save.
That’s it! Your Click & Drop settings are updated and will be applied to all the new orders placed in your store.
