To tweak the storefront's look and feel, you can use the built-in design options in the Design section of your store admin. Choose whatever size images, product card layout, category name position, and many more you want. Once you update the settings, they are immediately reflected on the store within your website.
What makes a storefront?
The storefront is the actual store where customers browse for products. Here’s what makes your storefront:
- Product list with product cards on it
- Product pages
- Store categories
- Navigation elements
Read on to learn how to tweak design for each of them on the Design page in your store admin.
Designing product list and product cards
The product list is the grid on the category pages or on the front page of your online store. The list is made of individual product cards that contain an image and content to give your customers a brief overview of a product.
That’s how a product card on the product list looks:
You can adjust image size and aspect ratio, hide or display elements like price, SKU, or the “Buy Now” button, and more using built-in design settings. For example, portrait image orientation is great for showing apparel, and large-size images are best for showcasing jewelry details, home decor elements, and so on.
The same image size and aspect ratio that you set for your product list are automatically applied to category images in your store.
To adjust product list and product card design:
- From your store admin, go to Design.
- In the Image size, Image aspect ratio, and Product Card details and layout sections, make the design changes you need.
- The changes are saved automatically.
Setting up product page layout
The product page is a page of a particular product in your store with all its details. Customers can access product pages by clicking a product card in the list, or by direct link.
You can set the product page layout and determine whether or not to show subtitles, SKUs, social media buttons, and other information depending on your business needs.
You can also choose the layout for image thumbnails on product cards. For example, if you have a gallery of high-quality photos for your products, it’s better to show full-size images so customers can pay attention to all of them. Additionally, you can zoom in on the main product image on hover.
To adjust product page design:
- In the Product Page layout, Image Gallery thumbnails, and Sidebar sections, make the design changes you need.
Setting up category name and image display
By default, all the products that you add to your store appear in the default category that is featured on the main page of your store. If you create more root categories or subcategories to make it easier for customers to navigate your store, they are displayed as a list:
You can choose where to display category names or hide names or category images completely. As for the category image size and aspect ratio, they will be the same as that you set for your product list.
To set up category name and image display:
- Scroll down to Category name position and choose your option.
In Design → Storefront navigation & colors → Category view, you can also expand root categories to display products they contain right on the store’s front page. For example, if you’re running a restaurant and want to showcase all the menu sections right away.
Learn more about expanding categories →
Adjusting navigation
Each store has a number of navigation options that create a better customer experience — “Previous” and “Next” arrows to switch between products, breadcrumbs, sorting option, product filters, and the store footer menu, including the “Sign in” link.
It’s up to you to show or hide these elements. We recommend showing them to make it easier for buyers to purchase in your store. You can adjust the storefront navigation in Design → Storefront navigation & colors and in Design → Navigation.
More ways to tweak your storefront design
Customizing your storefront is just a matter of your imagination and determination. For a more detailed setup of your store’s design, you can use additional tools:
- Product ribbons and product subtitles — colored labels and short captions that make products stand out on a storefront.
- Animated images — upload the .gif file as your prime product image, and it will appear on the storefront:
- Banners on storefront — to get customers’ attention to your hot deals, seasonal sale, social media, or anything else, you can add a banner to your storefront. The banner can be added to the store front page or to any of the category pages.
- App Market — here you can find apps that can be used to customize your site and store the way you want.
- In-depth customization options like CSS codes, custom development, and API.
