Product categories
Categories are groups of products that you wish to show on the same page in your store (for example, Women's Fashion, Men's Clothing, Bestsellers). They help customers to faster navigate through the store and find the products they need. The same product can belong to multiple categories at the same time. Read more about how to manage the categories in your store.
Creating categories and subcategories
The products from one category are listed on a separate page in the storefront. This page can have a description and a featured image. When adding an image, make sure that it represents well the content of the category.
Use the description to tell your customers what they will find in this category and what are the best things about the products there. Try not to make the description too long.
In store you can create a complex category structure with several levels. Categories of the first level are referred to as root categories. These are the categories your customers see in main navigation. You can also create categories of the second, third, etc. level within your root category. They are referred to as subcategories or child categories. The number of categories (and subcategories) you can have depends on the store plan that you are subscribed to.
Clear and concise category structure makes your store’s navigation intuitive. This allows your customers to find easily what they are looking for. That’s why we recommend planning your category structure before adding products.
Customers can navigate your categories and subcategories with the help of breadcrumbs – special links that show the path to the page they are currently viewing.
To create a new category of the first level:
  1. From your store admin, go to Catalog → Categories.
  2. Click Add Root Category.
  3. Enter the Name of your category.
You can edit the name of a category anytime later. To do it, just change the text in the Name field and save the changes.
  1. Click Choose file to upload an image for your category. You can upload an image that represents your category or an image of a product from the category.
  2. Enter the description. You can describe what kind of products are in that category, or just leave it blank.
  3. Click Save.
To create a new subcategory:
  2. Select the category into which you want to add a subcategory from the category tree on the left.
  3. Click Add Subcategory.
  4. Enter the Name of the new subcategory.
  5. Click Choose file to upload an image for your category. You can upload an image that represents your whole category or an image of a product from the category.
  6. Enter the description. You can describe what products are in that category, or just leave it blank.
  7. Click Save.
On the SEO tab of the category page in Catalog → Categories, you can add custom meta tags for your root categories and subcategories if you need.
Assigning products to categories
In store a product must belong to at least one category. So, when you add products without assigning them to any of your own categories, they are automatically assigned to the Store Front page category and appear as featured products on your storefront.
To show products in your own categories, you should assign them to these categories. You can add products to multiple categories at once. For example, an item that belongs to the Shoes category can be on sale and belong to the Sale items category as well.
To assign multiple products to a category:
  2. Select the category to which you want to assign a product from the category tree on the left.
  3. Switch to the Category products tab.
  4. Click Assign Products to Category:
  5. Select the necessary items in the list. You can filter the products by SKU and Name.
  6. Click Add products to assign items in bulk (or click the Plus icon to assign products one by one):
Also, you can assign a product to categories and move a product from one category to another right in the product's editing page.
You can also assign and remove categories in bulk for selected products right on the Catalog → Products page in your store admin.
To assign a product to a category:
  2. Open the product that you want to update.
  3. At the bottom on the page, see the Categories section and click Manage Categories.
  4. Select one or multiple categories that you want to assign the product to.
  5. (optional) Disable the Feature on the store’s front page toggle if you do not want this product to be featured in the store.
  6. Click Save.
You can see how many products are assigned to a category in the category tree in  your store admin in  Catalog → Categories:
It may take several minutes for the numbers to update in the category tree.
If one product is assigned to two or more categories, one of the categories will be marked as Default. The default category will be shown in the breadcrumbs on your product's page. For instance, if you assigned a coffee mug to the "Coffee" and "Mugs" categories and selected the "Mugs" category as default, breadcrumbs for the item on the products page will look like this: Home / Store / Mugs.
To change the default category:
  2. Open the product you want to change the default category to.
  3. Scroll down to the Categories section.
  4. Choose the category you want to make default and click the three dots:
  5. Click Make default and click Save:
Moving products from one category to another
You may need to rearrange products in your store and move them to another category. You can do this by exporting the products and importing them to a new category or by editing categories manually.
Exporting products and re-importing them to a new category
To rearrange many products, you can import them with new parameters. You need to export the products you want to change, edit them in a spreadsheet and then re-upload them to your store using the import feature. Please refer to the articles about exporting and importing your products.
Editing categories manually
You can manually rearrange categories for several products on the Catalog → Products or on the Catalog → Categories pages in your store admin. The first option allows you to assign and remove categories in bulk.
To rearrange products on the Products page:
    You need to create at least one category in your store (on top of the default Store front page category) before it becomes possible to assign or remove categories.
  3. Click Mass Update → Manage Categories → Assign or Remove Categories.
  4. Tick or untick the categories in the list:Bulk_Product_Editor__5_.png
  5. Click Apply.
The changes will be saved automatically. The categories will be assigned to/removed from all the selected products.
If you need to add featured products to the Store front page or remove featured products from the Store front page in bulk, you can also do that on the Catalog → Products page.
To rearrange products on the Categories page:
  2. Find the desired category in the left panel and click it.
  3. Open the Category products tab:
  4. Click Remove All. They are now uncategorized and will be listed on the storefront page much like featured products.
  5. Open the category where you want to move the products.
  6. Open the Category products tab.
  7. Click Assign Products to Category.
  8. In the popup, select the products to add.
  9. Click Add products:
  10. These products are now listed under the desired category.
Sorting products in categories
You can choose in what order to show the products in the storefront to your customers. Products can be automatically sorted by date added, by price or by name. Or you can set a custom order of products within a category and arrange the products manually in the desired way.
For detailed instructions, please visit Sorting products.
Changing categories order
If you wish to show some categories first, you can easily change the order of categories and subcategories.
To change the order of categories and subcategories:
  2. Drag and drop categories in the category tree:
Adding alt texts to category and subcategory images
Alternative text allows you to describe images for search engines and visually impaired users. It also displays if the image fails to load. This way, alt texts help users decide on a purchase and improve your site ranking, making it easier to find your products via images online.
By default, a category/subcategory name is used as alt text for each category/subcategory image. You can provide your own text instead.
To add alt text to a category or subcategory image:
  2. Click on the category or subcategory you want to edit.
  3. Hover over the image.
  4. Click Actions → Edit Alt Text:
  5. Enter your alt text. For example, “White table in daylight with makeup and nail products lying all over it.”
  6. Click Save.
That’s it. You’ve added alternative text to a category or subcategory image.
Disabling and deleting categories
If you wish to remove a category from your store, you can disable it or delete permanently.
Disabling a category
When you disable a category, it stops showing in your store. At the same time, you can see it in your store admin and enable it back anytime when needed.
To disable a category:
  2. Select the category you want to disable.
  3. Click Disable:
If a disabled category has enabled products, these products won't show in your catalog in the storefront, but they will still be available by a direct link and in search results.
Deleting a category
If you wish to remove a category completely, you can delete it.
To delete a category:
  2. Select the category that you want to remove in the category tree on the left.
  3. Click Delete category:
The products that were assigned to the deleted category will not be deleted. They will be moved to the Store Front page category.
Hiding category images
When you add a category in your store, you can upload your own category image, keep a default gradient image (it appears if no category image is added), or you can hide the category images across your store.
If you hide the category images, only category names will be displayed. Example:
To hide category images in your store:
  2. Scroll to Category name position.
  3. Choose Hide category images.
You can also hide product images.
Expanding categories
You can unfold root categories and display products from these categories right on the store front page. This category view is perfect for restaurants as it gives a menu-like look to the storefront. It also suits good the stores with small catalogs because customers can see all offered products at once.
Here is an example of how the expanded categories could look like:
To expand categories:
  1. Go to Design.
  2. Scroll to Storefront navigation & colors.
  3. Select Expand categories.
If you have more than 10 categories, 7 categories will shown as expanded in the storefront while others will be shown after clicking the Shop more categories link.
