Exporting customers
You can export your customer list to a CSV file.
  1. From your store's admin, go to the Customers page.
  2. Click Export All at the bottom of the list to export all your customers. If you want to export just a part of the list matching some criteria - use the filters in the column headers, then click Export all found. It is also possible to tick the customers you want to export and click Export selected.
  3. In the export settings dialog, select delimiter and the columns you want to get in a file and press Download CSV file.
  4. Save the CSV file.
Related articles
Collecting customer emails at checkout
